rtaylor0830's avatar
rtaylor0830
what temp should hub be with infared thermometer
For you guys who use infared (i am sure i am spelling it wrong) thermometers to check your hubs what temps are you looking for and is it normal to get different temps on different hubs on the same trailer.For example say you have been driving for 3 hours what would be a normal temp and should they all be the same.
  • I've seen my hubs reach 135*F and only 92*F. Summer time/winter time/sunny side-shaded side.
    I'm more concerned that I don't find one reading much higher than the other axle on same side of trailer.
    Not unusual for differences in temps side to side.....depends on which side is 'sunny'
    IF 10% difference in hubs on same side......time to be checking the bearings/brakes especially on the higher of the two.
    Same for tire thread, drums, rotors etc.
  • I think you should determine normal yourself. Make up a chart for each hub noting the outside temperature, and whether in the sunny side or the shady side of the drive.
    I also use mine to monitor tire temps.
    I had a hub go on the front of the truck and wow, did it ever get hot.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
