- Old-BiscuitExplorer IIII've seen my hubs reach 135*F and only 92*F. Summer time/winter time/sunny side-shaded side.
I'm more concerned that I don't find one reading much higher than the other axle on same side of trailer.
Not unusual for differences in temps side to side.....depends on which side is 'sunny'
IF 10% difference in hubs on same side......time to be checking the bearings/brakes especially on the higher of the two.
Same for tire thread, drums, rotors etc. - Artum_SnowbirdExplorerI think you should determine normal yourself. Make up a chart for each hub noting the outside temperature, and whether in the sunny side or the shady side of the drive.
I also use mine to monitor tire temps.
I had a hub go on the front of the truck and wow, did it ever get hot. - 2oldmanExplorer IIInfrared :)
