pianotuna
Aug 06, 2016Nomad III
What to do about voltage drop?
This is a continuation of testing of a Sola Basic autoformer.
Yesterday I tested on a 30 amp RV outlet at a private home in rural Saskatchewan which is fed by a 200 amp service. The panel is 2 years old.
Today, I tested on a 15 amp circuit with 60 feet of #10 cord and a 15 to 30 amp dog bone adapter. I used the Magnum hybrid inverter/charger to limit input to 15 amps to prevent overloading the circuit.
The results are:
Without autoformer
Shore power voltage in the RV 114.5 volts (fridge running drawing 331 watts)
Turning on the roof air voltage drop inside the RV was to 108.7 volts
demand was 1239 watts
With autoformer
Shore power voltage in the RV 114.6 volts
Turning on the roof air voltage jumped up to 119.3 volts inside the RV
The Sola Basic did not trip the GFCI, however the Magnum inverter does. The RV by itself does not trip a GFCI circuit.
I attempted to test a 50 amp outlet but could not get sufficient voltage drop to trigger the autoformer. I may try again with the water heater and toaster in the circuit.
My answer to low voltage is the autoformer. In an RV park a cheaper answer for a 30 amp RV may be to use a 50 to 30 dog bone adapter.
The previous part of this thread is at: Voltage report using a Sola Basic autoformer
The results are:
Without autoformer
With autoformer
