- 94-D2Explorer‘‘Tis the season” so to speak........
- randemarExplorerThx for all the help and advice. It did not look like I could easily get to the clamp at the water fill. Turns out the van has a few issues and I've elected to hire a mobile RV repairman. It is crazy here in the Phoenix area to get anything fixed in less than a month.
- 94-D2Explorer^^^^I had to use that driver to change my turn signal fluid^^^^^^????
- MrWizardModeratorUnclamp the hose at the tank
Than pull everything including hose out,
May have to unclamp house at back of fill,
Depends on how big of hole is in the wall
You do not take that apart, unless you drill out the rivets
It was not mfg to come apart, and not install in pieces - Lt46Explorer IIAre you sure you want to drill out those pop rivets? Seems to me the hose you want to replace should be clamped to that water inlet. Look around for access to the back of that inlet and you might see a hose clamp to remove.
- Ralph_CramdenExplorer IIThose requite a #7 double reversed schwansoculator driver.
Those are however really hard to find, a 1/8" or slightly larger drill bit will substitute nicely. - wa8yxmExplorer IIIThose do not look like screws (But detail is not that good) they look like POP rivets. you drill those to remove.
- HammerboyExplorerX4 on the drill and pop rivit.
Dan - Chris_BryantExplorer IIA drill, those are pop rivets.
- BarneySExplorer IIIMoved to Tech Issues forum from DIY.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Mar 12, 2022
