gmcman's avatar
gmcman
What would cause a shudder under load
This is on my stock tranny (4L60E) in an 02 envoy, I was taking my tandem axle 14' trailer (about 1300 lbs) for it's annual inspection and I felt a shudder under load. I'm almost positive the TC was locked in OD...about 50-55 MPH....usually is.
I was accelerating and when I was between 1/3-1/2 throttle, TC remained locked and the vehicle started to shudder but was progressive and not a hard shudder but almost felt like a bad U-joint. When I apply the gas at 50 ish, there is no shudder but when I hold the throttle position the shudder comes in lightly then amplifies and goes away when I let off.
There is no spike in RPM like a clutch pack slipping but I don't know...shifts fine and runs fine the rest of the time.
I have replaced the separator plate, 1-2 and 2-3 acc pistons and have the vette servo. Trans has 182K miles and fluid looks great, replaced 10K miles ago.
Fluid has always been replaced at 30-40K intervals
Rear was changed from factory 8.0" to a 9.5" SF and I just switched to Redline Heavy Shockproof fluid.
U-Joints are new and driveshaft was shortened and balanced.
Just curious if this could be a trans issue or not and if so where to look.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
