MrWizard
Nov 18, 2020Moderator
If you keep charging past when the monitor says 100%, then your AH counter will be out of whack and needs to be reset to zero once you do get to True Full.
NO !
My monitor and most other ones stop adding amps to the capacity value when the amps returned equal what was removed and set value is reached
Charging does Not Stop, but count does not increase beyond the set value
I think you are thinking of your way of a minus value from zero for amp hrs used then recharging to a plus value larger than zero to compensate and ensure you are at or near full,
Confusing what your display shows, with what is the normal operation of my system
