myredracer
Sep 20, 2017Explorer II
OP, can you post some photos of the interior of the EMS.
No way on god's green earth would I let a dealer install a PI EMS. Must be many thousands of these installed by other than a dealer and operate just fine.
I have to wonder if there was a bad connection(s) (despite thinking it was tight enough) or there was a surge from the poco.
What I do not like about these PI EMS units is the how the terminals on the contactor have flat surfaces and contact a round wire against 2 sides which could result in a less than ideal connection. If you look at a circuit breaker for example, the contact surfaces are concave shaped. When I installed our EMS, I used stranded #10 SOW cable to connect to the contactor.
Photo below shows the contactor and how a solid wire would be in the contact and you can see how a round wire is pressed against a flat surface by a flat-surfaced screw. Maybe as well, but I would think unlikely, bouncing in an RV from travelling down the road loosened a connection(s). I would hazard a guess that the average non-electrician would not know how much torque to apply to the screw.
I also don't like the way they want you to make the ground connection inside via a small stud on the side of the plastic enclosure. I wired the ground wire straight through with a wire nut then a 3rd wire over to the lug. I read about one case involving a lightning strike that fried an EMS and it's possible it was due to a poor internal ground connection.
*If* the OP's connections were not done properly I could see the manufacturer denying a claim, but without having the unit in hand, how would they know. The contactor itself could have been faulty too.
I hope they don't start making these things in China. PI's warranty has been stellar and hope this situation is an anomaly. I didn't think PI repaired these and normally shipped you a replacement?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
