MEXICOWANDERER
Sep 21, 2017Explorer
As an aside there is not one single compression set screw 120vac on board Quicksilver. The master 30 amp breaker...
The remaining Klixon AC and DC breakers all have nuts and bolts wire connections. With silicon bronze star washers under everything wires can never loosen unless I want them to.
I am convinced compression set screw devices are not suitable for stuff that vibrates. But every rig on the road uses them. Gee, is this why big rigs never use compression set screw connections?
Why the dual pole on a 30 amp circuit? This is Mexico, the land of reversed line leads.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
