milo
Sep 24, 2017Explorer II
SoundGuy wrote:milo wrote:
Where the unit would go is in a cabinet with a little cubbie hole 11" x 6" x 6" (Keystones fabulous engineering).
As you can see there's not allot of room in there.
Could you not increase the cabinet's available space by removing the "floor" of that top cabinet and utilize some of the lower cabinet space as well?
SoundGuy ... short answer is ...no. The water pump and cobweb of water lines fill the bottom 11 x 6 x 6 cubbie hole + the 2 television cables from the docking station. Still trying to figure out how I would get to the water pump if it needed work or replacement. If you look really hard you can see it in the back left side. Probably would have to tear the cabinet apart.
Milo
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
