SoundGuy
Sep 25, 2017Explorer
SoundGuy wrote:
BUT that's just my point - my Progressive EMS-HW30C is not enclosed, it's sitting on a rubber pad on top of the street side wheel well, under the sofa where there is plenty of open space around it and air can move freely. Explains why at most it's only ever warm to the touch, at most.
wnjj wrote:
I got your point but you missed mine. Because yours only gets warm, I'm concluding that it doesn't generate much heat. Flimsy RV cabinetry or even exterior walls for that matter will not trap enough heat to cause a "warm" object to get hot.
No, I fully understand your point ... my point is that any electrical device will generate some degree of heat so given that why enclose it at all when the alternative of not enclosing it ensures that none that heat can become trapped, regardless how little it may be? Seems like a simple concept to me.
One alternative the OP might consider is a totally self contained Progressive EMS-LCHW30C which he could mount somewhere inside his camper where it's display screen would be readily visible but trapping any heat generated by the device wouldn't be an issue.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
