wnjj
Sep 25, 2017Explorer II
SoundGuy wrote:
No, I fully understand your point ... my point is that any electrical device will generate some degree of heat so given that why enclose it at all when the alternative of not enclosing it ensures that none that heat can become trapped, regardless how little it may be? Seems like a simple concept to me.
It may seem like a simple concept but you're still not hearing me. The amount of heat that box makes will be neglible compared to the thermal properties of an RV cabinet. Of course an "enclosure" traps heat but it's the amount that matters. Keeping your heater turned up 2 degrees will make your unit warmer than one in a cabinet in a cooler RV.
It's a real stretch to assume that's what caused the OP's unit to melt. Resistive connections (which were tight) or the relay contacts are more likely the culprit.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
