wa8yxm
Sep 02, 2013Explorer III
Question: Do you have a 12 volt Accessory socket that is chassis powered and which is "HOT" when the ignition is off?
If so plug in a "Memory saver" (9 volt battery thing) from any auto store/department first.
Or you could hook a test lamp across the isolator solenoid (Which is how I will do it when the time comes)
The lamp acts as a self re-setting "Fuse" should you accidently short something.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
