time2roll
Aug 16, 2014Nomad
jrnymn7 wrote:If charging on generator I would probably shut down as charging dropped to 13.6 volts. At home you can leave it at 13.6 indefinitely. No need to shut down. All seems to be operating normal.
i've only had the new installs (charger and meter) for a couple charges now, so i'm just getting familiar with the new set-up. during the first charge, the meter was not hooked up yet, but i needed to charge right away. the second charge was done a couple days later, after little discharge. the 75 amp charger went into the 14.6v boost mode for only a short period (15 minutes maybe), and started at around 35 amps. so that seems to indicate a good read of the battery soc by the charger. it then dropped to 0.0amps momentarily as it kicked into the 13.6v absorption mode. it then ramped up to a little over 10 amps, and continued in absorption mode for about 5 hours, during which the amps dropped slowly to 2.4a, at which time it was after 11pm, so i shut it down.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
