jrnymn7
Aug 18, 2014Explorer
BFL13 wrote:
You can modify yours by drilling out the four rivets of the cover, remove that, put your voltmeter into the DC output terminals, and tweak the little blue pot's screw with a glasses frame sized screwdriver, and set the voltage to say, 14.6.
Not too clear if you crank it back to 13.6 it will still work as a 4 stager. Might not. I don't care with mine. Also forget the warranty :)
to what voltage can the pm be raised? and can one keep changing the voltage up or down to compensate for temp and equalizing vs. regular charging?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
