BFL13
Aug 18, 2014Explorer II
jrnymn7 wrote:BFL13 wrote:
You can modify yours by drilling out the four rivets of the cover, remove that, put your voltmeter into the DC output terminals, and tweak the little blue pot's screw with a glasses frame sized screwdriver, and set the voltage to say, 14.6.
Not too clear if you crank it back to 13.6 it will still work as a 4 stager. Might not. I don't care with mine. Also forget the warranty :)
to what voltage can the pm be raised? and can one keep changing the voltage up or down to compensate for temp and equalizing vs. regular charging?
It has a range from maybe 13-low15s? Anyway it is sort of fragile and not meant to be twiddled much. I set mine at 14.8 and nailed the lid back on. No more changes with that tiny little blue pot. :)
If you want the one with the variable voltage that is meant to be twiddled (has external knob) check out that Boondocker Deluxe version Randy is coming out with soon on bestconverters.com
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
