BFL13
Aug 18, 2014Explorer II
jrnymn7 wrote:
anyone know how long the pm4b has to be in float before the equalization stage will kick in? thanxx!
ISTR it is once a week but doesn't matter. You must not confuse "equalization" in that context with "real equalization"
The converter in float does a brief stirring if the electrolyte once in a while to counter stratification. Converter makers call that "equalization" for some strange reason.
Nothing to do with actual "equalization" which is a major episode to desulfate the battery and bring all cells to equal SG. The Equalize feature of the VEC1093DBD is for that. Also you can do it with a manual charger that will not shut off by itself at 14.4v like those "automatic" chargers do (but "manual chargers" stay on until you shut them off) but those manual chargers need to have decent amps like 10a, not a 2 amp trickle type or it will not have the oomph to get the batts over 15v and to near 16v as required to actually equalize them.
Suggest reading all the bumph on how to do batteries in one of the major battery maker's websites such as Trojan's. It will be the same sort of thing for your batteries.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
