NinerBikes
Aug 20, 2014Explorer
As you run out of sulfur on the lead plates to put back into ionic solution in the battery acid/electrolyte, at constant voltage, the amps will taper. The acid runs our of chemical reaction capacity as your Specific gravity reaches maximum... there is no more usable sulfur on the plates to go back into the solution. No sulfur to put in solution, no amps can flow, except those used for hydrolysis.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
