mena661
Aug 20, 2014Explorer
BFL13 wrote:I use the VEC when I don't have time but with the power supply, it takes a LOT less time because of the much higher amps so I probably won't use the VEC anymore for that. Mine starts at 24A and tapers to 9 and holds there (the taper is probably much slower by then). It seems that once it gets to the "holding" amps, the SG is where it should be at that point. I need to use it more to verify. Finish charging would probably take 30 mins on your bank BFL.
Great way to equalize because no babysitting, you can let it run overnight while you sleep :) The classic method with a manual charger means you have to be there and shut it down yourself before it overdoes it. Sometimes to get the SG back to baseline I have to run two Es in a row with the VEC. Get the first FUL then restart and do another E and it will run for more time with amps tapering till says FUL again.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
