jrnymn7
Aug 20, 2014Explorer
MENA wrote:
I use the VEC when I don't have time but with the power supply, it takes a LOT less time because of the much higher amps so I probably won't use the VEC anymore for that. Mine starts at 24A and tapers to 9 and holds there (the taper is probably much slower by then). It seems that once it gets to the "holding" amps, the SG is where it should be at that point. (end quote)
so you just let the batteries decide on the starting amperage?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
