BFL13
Aug 20, 2014Explorer II
"the nes-350-15's only put out 23 amps. my Peak Perf... 40amper would hold strong at 40 amps at 14.8v for at least an hour and a half... and that was starting with the batts at 14.6 volts. i'm not sure if the charger was junk and reading wrong, or if i need at least 40 amps for abs??? the pm drops from about 43 to 33 during the first 15 minute boost mode when starting at 14.6v battery state. that's all i have to go on at this point. "
Some confusion here (mine anyway! :) )
You can't tell the "starting state" of a battery by its voltage unless it has been resting a while. What were the batts doing before you started charging that they were already at 14.6v? Must have been getting charged up somehow already.
If you want to charge at 5% of 430 = 21 amps call it 20, you could do it with two 10ampers at once on all four or split the bank and do a pair each at 10a. As long as each 10amper has the power to do 10a at 16v
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
