jrnymn7
Aug 21, 2014Explorer
BFL13 wrote:
(es I thought you were running them together.)
The Trimetric only shows what the battery is taking. The charger shows everything it is doing, battery and running any loads. Your fridge etc are a load of about 1 amp so the charger was one amp higher than the battery. Same thing happens with solar.
The loads get handled first by the charger, so once the loads and the battery together max out the charger's amps, then the loads keep getting theirs and the battery gets less.
On the Trimetric it looks like it shows "net amps" but that is just how the math works, not what is really going on. It can be easier on the brain to pretend it is net amps though, since you get the right answer of in and out (charging/drawing)
yes, of course, i had forgotten about the fridge draw... when running the pm, there was no readout to compare to. thanxx once again!
and this would also account for the amps and volts bouncing up and down, for i've noticed the amp draw of the fridge changes from 0.7 idle to 0.9 when cooling.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
