azrving
Aug 21, 2014Explorer
Per Lands comments about resistance a while back: What size cable is your converter running through?
How many feet to the batteries? Mine was about 30 plus as it crossed to the other side and back.
Did you check voltage at the converter positve vs pos terminal of batt for voltage drop?
I also did what Land said, checked everything with temp gun and found that an anl stereo, gold, pretty boy fuse got much hotter than an industrial type anl. I dont remember the V drop.
I also upped my catastrophe fuse as it was getting hot. I was too far under sized.
Also had a warm spot at my system ground.
I'm still interested in your high water use. Was it all the top charging when maybe the sg was ok? I may be wandering off but just wondering and learning.
And Mr Mex, us beginners may be wandering some but you haven't seen any spitballs, mad magazines or playboy during class. :)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
