jrnymn7
Aug 22, 2014Explorer
BFL wrote:
"If you have four batts and two 40ampers, you can put both on the four or one on each pair and it will take the same time because your charging rate is the same in each case 40 on two is the same percentage of AH as 80 is on four."
yes, but i was comparing using the same charge amps on two different size banks, i.e; 40 on a 215 vs. 40 on a 430. sorry for any confusion. i probably shouldn't have said "splitting the bank" but rather "eliminating one pair and reducing down to a 215ah bank". i will -- EDIT -- the post to better reflect what i meant.
a 40a on the 215 bank should be more than twice as fast as a 40a on the 430 bank, correct?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
