jrnymn7
Sep 05, 2014Explorer
rjxj wrote:jrnymn7 wrote:Canadian Rainbirds wrote:
Looked it up, looks interesting. Here's the Clicky But with the Canadian dollar at 92 cents and the shipping . . .
still, by far, the best deal for a 20amp power supply with 0-20a and 0-16v fully adjustable range... and good for boost, abs, and top charging, as well as eq'ing, and long term float.
at $115 u.s., with shipping, it's still cheaper and way more versatile than anything else out there. and if you don't mind spending the big bucks, you can get up to a 100a unit.
i'm thinking this is the way to go.
It may be a little light on the amps side. You are running 4 batteries with about 400 plus ah right? Do they make a 40 amp?
not in that price range or series... they have up to 120amp... the gopher gps-640U is a 16v / 40a unit...http://gophertc.com/en/gps
i only need low amps for topping and eq'ing. the (modified) pm will do my boost and abs. and i've decided to split the bank into two 215a/h, so the 20a unit should suffice.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
