jrnymn7
Sep 05, 2014Explorer
BFL wrote:
"Now when you charge the batts, the charger will run at constant 75 amps till batts reach 14.8v (however long that takes) then stay at 14.8 while amps taper and stay at 14.8 for as long as it is plugged in, you have to shut it off.(end quote)
o.k thanks
??? will it boost 'til 14.8v or 14.6v before switching to abs?... (i've never been sure what is meant by the abs threshold... whether it's the abs voltage or the max boost voltage? in the pm4b's case, it's the latter, 14.6). or will it not kick into abs at all, but rather stay in boost essentially?
(also, please see my EDIT in my other post, thanks)
o.k thanks
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
