jrnymn7
Sep 06, 2014Explorer
BFL wrote:
"Now whatever the batts are at, they will rise to 14.8 under that 75a current. When they get there, since that voltage is constant, amps will now taper. The charger will stay at 14.8 forever and now so will the batts until you unplug the charger." (end quote)
I actually mis-spoke earlier concerning the pm's behaviour, when charging from 11.9v / 40% soc. it didn't actually start in abs, (nor did it start in boost). but rather, it started at 13.02v and 45.7a, and continued on to 13.61v and 12.5a; after which it kicked down to float at 13.15v and 3.2a. so, it had rising volts (like in bulk), but tapering amps (like in abs) ??? it did neither a bulk or abs charge, but some combination of both. this is why i'm concerned with whether it will respond properly to my mod.
... moreover, i just finished doing a discharge of 200 Ah, plugged it in, and the same thing happened... 13.03v and 45.7a. so, i unplugged it, and will try again soon.
UPDATE: after the very short charge that replaced about 3 Ah, the batts rested for about an hour and a half... soc was 12.34v at (-)196Ah. plugged in the pm and got 45.7a at a little less than 13v.
so, it would appear the 75amper is actually a 45.7amper???
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
