jrnymn7
Sep 13, 2014Explorer
BFL13 wrote:
I doubt the new PMBC will have PFC below that 75a rating. None of the other PM chargers do. That was all about the converter still being able to run on a 15a circuit. A non PFC 60amper can run on a 15a circuit. eg the PD 80amper needs a 20a circuit, which means 12wire instead of 14 etc.
I have lost track of the main objective here or it is changing :) IMO the thing to establish first here now is whether the mod-PM75 can charge a 50% SOC pair of batteries by doing 75 amp constant for longer than 15 minutes at the high voltage setting such as at 14.8.
Or find out what it will or won't do and if you can adjust it some more to get it to do what you want.
just considering my options if the 75er doesn't work out... thinking out loud, if you will.
and on that note, i think i have the answer to my original question of when the pm4b should go into float mode? ... right after i toss it in the lake!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
