dougrainer
Dec 31, 2016Nomad
johnhicks wrote:
I have an Intellitec IRD, not BIRD. Would changing be a simple swapout or would a Trik-L-Start make more sense?
'93 HR Imperial, Oshkosh chassis w/6BT 5.9.
Oddly, the IRD is up front on a board with what appears to be some sort of solenoid, which another solenoid resides in the battery bay.
You have a BIRD. IF the solenoid connected to your BIRD has Chassis on one side and the coach on the other side, You can connect the true dual mode Intellitec BIRD. You are trying to utilize the Chassis charge method when on Shore Power? If so, using the Trik-L-Start is a better way to go. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
