MEXICOWANDERER's avatar
Nov 16, 2017
Where To Buy? 22AWG 7 Conductor Wire For Shunt Lead Extend
Could be 20AWG or 24. Can be 8 leads. But different colors. I need to add 25'
Thermostat wire is solid conductor. A bit leery of exposing it to vibration - the conductors are tiny.
  • I’ve used cat V in several installations, works well just kinda messy. Just installed a Victron unit, they use a data cable you just plug into the shunt & meter, run one wire to battery positive, very neat. Also, with the dongle has Bluetooth capability, don’t even need the "install" the meter.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Electronics supply houses.. Alas the one I used to use is no longer open to the public Let me check one ohter
    www.allelectronics.com has Cat 5 and cat 6 24awg cables 8 wire
    These are standard computer cables by the way (LAN cables) used for data transmission.. Green Green with stripe.. Orange Orange with stripe and so on.
  • 4x4van's avatar
    4x4van
    Explorer III
    Home improvement store would be easiest/cheapest; look in the irrigation section for sprinkler control wiring. Solid conductor should hold up fine, IMO. Otherwise, Google 8-conductor stranded wire; lots of results.
    Here's some
