- gmctoymanExplorerI’ve used cat V in several installations, works well just kinda messy. Just installed a Victron unit, they use a data cable you just plug into the shunt & meter, run one wire to battery positive, very neat. Also, with the dongle has Bluetooth capability, don’t even need the "install" the meter.
- wa8yxmExplorer IIIElectronics supply houses.. Alas the one I used to use is no longer open to the public Let me check one ohter
www.allelectronics.com has Cat 5 and cat 6 24awg cables 8 wire
These are standard computer cables by the way (LAN cables) used for data transmission.. Green Green with stripe.. Orange Orange with stripe and so on. - 4x4vanExplorer IIIHome improvement store would be easiest/cheapest; look in the irrigation section for sprinkler control wiring. Solid conductor should hold up fine, IMO. Otherwise, Google 8-conductor stranded wire; lots of results.
Here's some
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
