NinerBikes
Mar 22, 2015Explorer
MEXICOWANDERER wrote:
Shopping with this phartsmone is impossible. 33 WEBPAGE NOT AVAILABLE or Amazon is having problems try again later...
If I am looking at 500 dollars I'll have to kiss this off. But I'll need 100% of 30-amp hours. I have no idea if NiMH can endure 0% remaining discharges. 10 D cell TENERGY 14 amp hour rechargables cost a hundred dollars.
Weight is critical. Maybe eight pounds or so maximum. The Lifeline is going to have to stay home under my bed. The Respironics must be used with the humidifier anabled. No choice. Thank you
You'll need probably 40 amps of battery capacity to get 30 amps useful without killing the LI battery.
NIMH are fine with full discharge, better to leave 5 to 10% in them though. 300-400 cycles max with the NI MH in the type of conditions you mention. No idea on the weight...
Tenergy 8 pac D cells
