Simplygib's avatar
Simplygib
Where to buy locking seal for cabover window glass
I've got an old Six-Pac Truck Camper whose front cabover window has been leaking around the rubber window glass locking seal (between the glass and window frame). I would like to replace that seal, but am not sure where to find one.
I pulled out one end of the seal to take cross sectional photos of it, shown below. One is a little blurry - sorry.
Anyone know where this type of material might be available? I've checked Amazon and a couple of online sources but can't seem to find a piece that matches this cross-sectional view.
  • I couldnt find my leak until I turned it upside down in a bath tub and watched where water came in at. Cab over windows get a lot of vibrations imo.
  • Thanks for the info. Yes, path1, those front cabover windows are a big pain.
    I got lucky on the locking seal. A local glass shop had it. I wasn't aware that it wasn't what kept the water out though, so I guess I'll have to pull the window and apply some sealant between it and the frame. Thanks again, it will be great to get this thing sealed up.
  • Imo...Rubber just keeps out most of dust and junk. Several different sizes and shapes so I pulled window and took to glass shop that was familiar with RV windows, and had window resealed to window frame. One piece cab over windows big pain.
  • Chris Bryant wrote:
    That is called glazing, and it holds the glass in, but isn’t what keeps after out- as Drew said the seal is between the glass and frame.
    Assume you meant "keeps water out"?
    That is called proof reading your posts before hitting "Post Message". :C
  • I replaced all of the rubber seals on my windows earlier this year. I got them from Pelland Enterprises. They have a $4 sample kit that you can order to make sure that you get the correct seal. My MH required 3 different seals to do all of the windows. There is some kind of double-stick tape that holds the window in the frame, but it needs the rubber seal to stop water and air infiltration.
  • That is called glazing, and it holds the glass in, but isn’t what keeps after out- as Drew said the seal is between the glass and frame.
  • Captain Tolley's Creeping Crack Cure? You may be able to source some at a marine hardware shop like West Marine.
    Replace the existing rubber seal and then edge it with this stuff.
    Try googling it first.
  • DrewE's avatar
    DrewE
    Explorer III
    I think typically that seal isn't what primarily is keeping the water out (or not), but rather there's a polyurethane adhesive seal between the glass and the frame itself. The rubber piece is to hold things in position, and make them look pretty, and probably to keep too much water from collecting between the glass and the frame in general.
    It would probably help in finding the rubber material if you could suss out the manufacturer of the window itself (on my RV, for example, they're Hehr windows).
