wa8yxm
Sep 02, 2013Explorer III
You should be able to get it at most larger RV dealer stores or at Camping World. and Smaller RV dealers can order it.
HOWEVER. the break is clean so why not just fix it.. Here is how
if you look at the photo and imagine the track as a lower case "t" sitting on it's side. the "Track is the top of the "T" (on the right as you look at it)
You can line up the two ends of the broken piece, put a THIN layer of GOOP on the end and press it together and fix it (Use a vice or other clamp to keep them aligned) let dry for a few hours then glue a craft stick to the back side (Left in photo) to add strength.. Let dry overnight and re-install CAREFULLY 2 person job. At least till you find a replacement.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
