Dusty_R
Oct 10, 2017Explorer
It doesn't really matter. Just for fun check a tire in several different locations. I'll bet the temp will be the same no matter where you check it, if you do it as soon as you stop after driving for half an hour.
I use a radiant thermometer, and check out tires when we stop for breaks. The temperature may vary from tire to tire as much as 10 degrees, depending on the sun. Over 10 degrees and I start to worry.
Dusty
Dusty
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
