NW_Etrek_Owner's avatar
Nov 15, 2020
Where's the Webasto Diesel heater fuses on an 2015 Etrek
Hi, new to the forum, so go easy on my beginner errors ;-) We purchased a very lightly used 2015 etrek which for where we live is a great camper van. We needed to turn the Webasto Duo heater the other night for the first time and got a 10 red blink code which appears to be something we could reset with a reboot. But to do that you need to pull and reinsert 3 fuses in a particular sequence. Nowhere in anything from Etrek does it say where they installed these fuses -- not with the others. Installation manual says they should be installed on the interior but tracing the wires get me nowhere starting from either the control or the heater its or any known fuse location. Anyone familiar with this? Probably a typical installation spot but I was surprised I couldn't find any Etrek forum anywhere with useful information. As techie as these vans are seems someone would be sharing issues. Will say it drives great and the battery only boondocking is working for us -- nice not dealing with propane and internal flames in the rig. Thanks in advance
  • Success!
    Never found anyone who could tell me where these fuses are in the etrek 2015, but I did find a couple of folks who confirmed it likely would not be with the other fuses, somewhere inside, maybe under the dask?
    But the fuse box for MB Sprinter vans where all the circuitry to the back is funneled and it's on the driver side step wheel. So I figured it would be smart to put these webasto fuses near there. And by golly I found the 3 fuse box under the seat -- push the seat forward so you can reach in the base behind real fuse box where they wired it in..
    Once found, the reset process pulling the fuses to do the reset worked fine and I'm up and running.
