albow
Mar 17, 2018Explorer
LarryJM wrote:Acrylic is only available if you have a cover for your awning to roll up into, which mine does not. It is exposed. Why, I don't know, I just know a manufacturer said so.albow wrote:
Thanks for the replies so far, but none actually answer my question of which fabric is the best among the ones I listed. I would choose the acrylic if it would work with mine but it won't, and comparing these others to each other isn't exactly straightforward. I may have to just call one of them and ask so I can learn. Out of the ones I listed, one is a clear cut better price and seems to have heavier fabric, but also is the only one that says it is heat welded rather than sewn, which makes me wonder if that's why it is so much cheaper. If not an issue, then certainly it would be the one to choose. I do see where everyone who bought from them is satisfied.
I don't understand why you say you can't get acrylic. Not sure how much it matters but I would think a solid vinyl and not one glued together in layers would be more durable. I've seen more than just a few posts here on the layered awnings coming apart. Toughtop seems to be a favorite here.
Larry
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
