Barry_J's avatar
Barry_J
Which recoating product to use
Ok so some people are saying do not use silicone to coat the camper roof and around the vents. I was looking at the Henry products because someone told me it works great, but the product that the Henry people suggested was the 887 which is 100% silicone, another roofing product they have is 100% acrylic, can someone help me to get the right product to re-coat the roof and seal around the vents, with hopefully the same stuff
Thanks
Barry
  • I used Liquid Roof on mine 4 years ago and it's held up great. I use Dicor's self-leveling lap sealant for touch ups around vents and other protrusions through the roof.
  • Barry J wrote:
    .. I need a coating that will be either brushed on or rolled on to cover a bigger surface than the lap sealant is able to do
    I use this stuff regularly: Heng's Rubber roof coating
    Had a leaky skylight that only that product generously applied worked.
  • Barry J wrote:
    Because I need a coating that will be either brushed on or rolled on to cover a bigger surface than the lap sealant is able to do
    Since Dicor - and I guess others - make roll on coatings SPECIFICALLY for use on EPDM roofs, why would you screw around with something else that probably won't work as well, and may well fail for you causing even more problems?
    https://dicorproducts.com/product/epdm-acrylic-rubber-roof-coating-cleaneractivator-part-1-of-epdm-roof-coating-system/
  • Look at EPDM coatings. They get good reviews and there are a lot of self help and DIY videos on the product.
    https://www.epdmcoatings.com
  • Because I need a coating that will be either brushed on or rolled on to cover a bigger surface than the lap sealant is able to do
  • Barry J wrote:
    Should I be using Silicone , like I said some people are saying no
    Absolutely not. Why would you not use readily available self leveling lap sealant that's specifically made for this purpose? :@
  • Should I be using Silicone , like I said some people are saying no
  • I use Dicor sealant, it is the same stuff the factories use and what is compatable with the Dicor rubber roof that is on the majority of the RV's.
Having RV issues? Connect with others who have been in your shoes.24,296 PostsLatest Activity: Aug 06, 2025
