dougrainer
Mar 23, 2016Nomad
RED goes to positive. On RV's Red and Black are positive. WHITE is negative on RV's. If you disconnect the battery, and plugged in and the lights are not bright, then either the Converter is bad or its fuse is blown which will happen if you made a mistake on the battery cable hook up. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
