rjsurfer
Dec 09, 2016Explorer
westend wrote:rjsurfer wrote:
Those "hex" head screws are horrible, you have to make sure the driver is perfectly aligned to the and even then when driving into new material they slip off.
Ron W
Ron,
Have you had the misfortune to try Clutch "G" heads? My Starcraft is full of these and I've pitched a few hundred, replacing them with a different screw type.
Those hex head screws are easy to drive with the correct bit. I've driven thousands of them when I was in the steel building world.
Maybe that was my issue with hex heads, they never really felt solidly held by the driver socket, very wobbly.
If I ever decide to use hex heads I will bring the driver with me and check the fit.
Thanks
Ron W
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
