Iceman31's avatar
Iceman31
White piece of plastic came off slide out - need help
When I opened up my FW at my seasonal site tonight a big long white plastic piece with holes came out on the under side of the main slide out. Looks like it was fastened at two ends by screws. How should I go about putting this plastic piece back - where does it go? I just noticed it hanging below my slide out when I went outside. My unit is a 2013 Sabre 34TBOK. My slide only opens in the spring and closes in the fall. Anyone know how to fix this?
  • Most Nylon Glide strips have multiple holes because just having 2 screws on each end will not hold it in place. IF you have the multiple holes, make sure you install a screw in each hole. If you do NOT have multiple holes, I would drill and countersink a hole every 12 inches to install additional screws. IF you have multiple holes and they only used the 2 end screws, that is why it failed. Doug
  • It goes under the slide at the edge of the wall and the entire s/o "slides" over it as it travels in and out. This type doesn't usually have rollers, just that slippery white guide.
    Without it you will tear up the bottom of the slide. It was probably broken the same way mine was, by stepping on the unsupported floor of the slide while it was in.
    The slide will have to be lifted or even removed to screw the piece back in. Mine wasn't that bad, just cracked, so I installed rollers to help support the slide. A much better system.
    I'd post a pic but Photobucket lost all those images.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
