FIRE_UP's avatar
FIRE_UP
Who is schooled in "Grease"? (Need some tough stuff)
Gents,
I'm always on the lookout for a good grease. I've bought and used them all from auto parts stores, Walmart, and other NORMAL outlets for that kind of stuff. But, so far, all the ones I've used are to me, barely acceptable in certain applications. For the normal ball joints, tie-rod ends, drive shaft u-joints, and a few dozen other applications, most of the regularly supplied greases found in the places mentioned above, will suffice.
There are times when I need something considerably stronger and will withstand compression and "sqeeze-out" much better than the normal ones. Now please don't ask why I need such a strong grease and where I plan on using it. That doesn't matter. I need it, and that's all that matters. I know there's got to be a mil-spec or industrial strength grease out there that is attainable from us laymen.
So, who's got some "inside" info on a very special grease out there?
Scott
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 05, 2025
