dougrainer wrote:
Let me get this straight. Dometic makes hundreds of thousands of this model toilet. They are in scores of models. You have a DEFECTIVE one. So, you blame ALL the 300 toilets and the designer. Get a life. You fixed yours. Dometic sanitation have a 2 year warranty. If you go thru the proper procedure, they will replace your defective one. Doug
I agree, this post from Doug, is unfriendly, and unwarranted! Yes Doug, you are often helpful/knowledgeable, but need to work on your demeanor a little.:W
Jerry
