- MFLNomad II
wolfe10 wrote:
Open a faucet. If there is an air pocket, that will aid in bleeding the air out.
If that doesn't work, open the kitchen sink faucet, and with the pump turned on, suck on the faucet. That will, as above, help bleed the air past the pump.
I agree with the first part, but that sucking the faucet, should not be necessary, unless a roach is trapped in the line.
Also don't be afraid to let the pump run dry for a bit, waiting for it to prime. It will not harm it.
Jerry - Check your settings in the wet bay. You may be feeding water from the tank to the tank.
- wolfe10ExplorerOpen a faucet. If there is an air pocket, that will aid in bleeding the air out.
If that doesn't work, open the kitchen sink faucet, and with the pump turned on, suck on the faucet. That will, as above, help bleed the air past the pump. - traildogExplorer
midnightsadie wrote:
check fuse. if your reading the empty/full gauge? they are not very good at telling the true water left in the tank.
Pump runs but doesn’t pump. - traildogExplorer
pianotuna wrote:
How old? What make and model of pump?
Camper is 2 years old. I looked at the pump but I’ll have to get the make and model later today. - traildogExplorer
schlep1967 wrote:
Pump is self priming. How did you verify the tank is full?
I pulled the drain, let some of the water out and then refilled it. It’s full. - midnightsadieExplorer IIcheck fuse. if your reading the empty/full gauge? they are not very good at telling the true water left in the tank.
- pianotunaNomad IIIHow old? What make and model of pump?
- Pump is self priming. How did you verify the tank is full?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
