Golden_HVAC
Oct 07, 2014Explorer
You will be happy with 6 volt batteries. They carry so much more water.
Actually you could stay with group 8D 12 volt battery, it is about 220 amp hours at 12 volts in a single (somewhat difficult to lift) 120 pound battery. After installing a pair of 67 pound batteries, you will be very happy that you picked the 6 volt golf cart batteries, in two easy to lift packages!
Yes it is about 62-67 pounds. Lots of lead, probably a gallon of water / acid mixture in each battery. The group 24 is less than a quart of water/acid mixture, and so much lead. You will be going from a pair of 65 AH batteries "lab rating" or total of about 80 real world amp hours to 220 AH and real world around 125 AH usable.
Get a solar panel, and you will be really happy while dry camping!
SunElec.com
Fred.
SunElec.com
Fred.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
