opnspaces's avatar
opnspaces
Navigator III
Dec 31, 2018
Why have I dealt with this charger for 13 years?
My 2005 Jayco has an IOTA 40 amp converter charger that has always struggled to charge the batteries while on generator. Well this weekend I finally got curious enough to put a meter on it. While I did record the charging voltage every 10 minutes, there really wasn't much change. Here's a condensed view of my chart.
  • 9:00 am 11.74v
  • 9:10 am 13.37v
  • 9:30am 13.77v it never got higher than 13.77
  • 9:40 am 13.47v
  • 12:45 am 13.30v
I am in the desert with no neighbors so I gave up recording at this point and just let the generator run all day.
the next day I did two things.
  1. I used the super expensive fuel inefficient charger (the truck and jumper cables) to make sure I would have heat for sleeping
  2. I decided enough is enough I'm going to get a replacement charger.
I do plan to call Randy at Best Converter, but figured I'd ask some opinions from all of you as you hopefully have no vested interest in the converter I ultimately decide on.
Should I go with a replacement IOTA, or a progressive dynamics, or a boondocker or? How many charge amps? I'm running a Honda EU2000i to the shore power cord.
Thanks
Edit because I forgot important information.
I'm running two 6volt Costco batteries.
I checked multiple times and there is no port for the IQ4 charge controller
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 29, 2025
