mena661
Aug 20, 2014Explorer
landyacht318 wrote:You can use 80% of LI capacity (less than that and you're down the curve on cycle life) and still get more than double the cycle life of lead acid. Lots of people are running 2 6V at 232Ah. A single 160Ah 12V LI batt would give them a bit more usable capacity than the 6V's plus you can run a microwave from them at low SOC's without massive voltage sag and Peukert. That website that PT linked has 160Ah "cells" for $170 each, so $680 for a "12V" batt. You can get an inexpensive BMS from HERE which covers cell balancing, high and low voltage cutoffs, and some other stuff. That will probably cost around $100. Then there is copper bus bars, and some strapping to hold the cells together. If you're gonna go this route, read, read, read then read some more.
I do wonder how long before Lifepo4 becomes affordable. No peukert, no worrying about partial discharge storage, ability to accept insane charging currents, support huge loads.
No more 6v vs 12v threads..........
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
