AH_AKExplorerApr 12, 2022Why solenoid?Why do the majority of RV manufacturers use a latching solenoid for the battery disconnect (storage) as opposed to a mechanical battery disconnect switch? Is there some other function that the sol...Show More
2112Explorer IIApr 13, 2022PT, I'm surprised you didn't replace the continuous current draw disconnect relay with a latching type. You seem to be very efficiency minded.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentAuxiliary Start Solenoid ReplacementBattery Disconnect Solenoid FuseDelete a Propane Solenoid Safety Valve?Testing solenoidBattery Disconnect Solenoid
