AH_AKExplorerApr 12, 2022Why solenoid?Why do the majority of RV manufacturers use a latching solenoid for the battery disconnect (storage) as opposed to a mechanical battery disconnect switch? Is there some other function that the sol...Show More
wa8yxmExplorer IIIApr 13, 2022I have had to bypass my solenoid.. ONCE.YOu can install a bypass switch for emergency use. Easy to do.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentAuxiliary Start Solenoid ReplacementBattery Disconnect Solenoid FuseDelete a Propane Solenoid Safety Valve?Testing solenoidBattery Disconnect Solenoid
