tonyclifton
Jan 05, 2022Explorer II
Yes, tho is a C46540. I went back and corrected my original post. Thanks for catching that!
I am using the 4-prong connector and apparently was not sufficiently aware of the specs! The diagram in the manual identifies it as a L14-30R.
I was not aware that the AVR was only on one phase.
I have a kill-a-watt. Low load voltage was 129v. Seems high. One circuit (with the coffee maker) only dropped somewhere between 120 - 125v when I made coffee. The other leg with the microwave dropped to 96v (coffee maker was not running). Is this related to the AVR only functioning on one phase? That leg really drops and has no other major draws on it.
My goal; is to power both legs of the building circuit, although selectively powering certain breakers to manage load. I turn off high draw circuits like heat pump, water heater, sewage pump, range. What type of generator output / receptacle will do this as I shop for a replacement generator? I know this unit is getting old although has been a rock solid runner ever since I bought it based upon extensive reviews here.
Love this site and it’s well informed users!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
