belfert's avatar
belfert
Why won't Yamaha EF6300iSDE generator start A/C on 240 volt?
I have a Yamaha EF6300iSDE inverter generator. I have 50 amp service in my RV. When I plug into the 120/240 outlet none of my three rooftop A/C units will start. The generator will show 50% on the power graph and the overload light comes on.
Now, if I plug into the 30 amp 120 volt outlet with a 30 amp to 50 amp converter I can start any of the A/C units. In fact, I can run three rooftops on the 30 amp plug with the compressor running on all three.
Why would the rooftops not work when in 240 volt mode with a 50 amp connection? Is 26 amps on one leg just not enough to start a rooftop even when it is 75 degrees outside?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
